Hello:
I am writing this message, because I detected that the shock was installed incorrectly form factory, the valve is in the right side very close to the frame causing the following issues:
- Is very complicated to add air because the pump hose conector has not space to join with the shock valve or the frame could be scraped in this process
- In case that use the entire suspension travel, the shock valve can damage the frame (front shock holder).
For these reason I require to rotate the back of the shock absorber to the left and bottom side of the frame, but I need to know how to dismounting the shock because it has a bolt and internal pin that holds on the link.
Please could any one help me with the instructions to remove the pin.
I am sending some photos to explain better this situation.
Thanks
Martin
